Re: Anti Freeze Leak
Posted by El Toro on January 25, 2010 at 06:41:08 from (74.103.74.58):
In Reply to: Anti Freeze Leak posted by nyvines on January 25, 2010 at 05:55:57:
When I split the FarmallA I had I set a 12X12 block under the drawbar, then blocked up the engine and then unbolted the steering from the block. Then rolled the front wheels with the steering wheel from under the engine. The hood, radiator, grill and head were already off this tractor when I bought it.
I used an engine hoist to lift the engine after I had removed all the bolts. Keep your bolts separated makes it a lot easier when reinstalling. I use cardboard boxes. Good time to look at your clutch while you have it off. Make a note how the clutch disc faces when removing it so you have it on correctly when reinstalling it. If it's worn close to the rivets have it relined or buy another disc. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
