Posted by kossuth on January 25, 2010 at 07:35:28 from (214.3.140.16):
In Reply to: New engine knock posted by bkpigs on January 25, 2010 at 06:25:07:
eastsider said: (quoted from post at 07:25:07 01/25/10) Ok...I have been stewing on this for a month or so now...I have been rebuilding my 51 H for three years...it has been completely, and I do mean completely taken apart...every bolt. Engine was hot tanked, crank turned, cam bearings installed at the machine shop, new stepped pistons, sleeves, bearings etc... We fired it up for the first time and ran like a champ...however, there is a light "knocking" sound. It seems like it could come from the gears in the front, or possibly #1 cylinder. Shoot me some ideas before I tear everything apart and more of my hair out...this tractor was my grandpa's and was a complete basket case...we have combined parts from three different H's to bring it back to life... Everything was torqued properly etc... Would a loose gear make a noise like that? Any thoughts would be appreciated.
Could be a timing gear, could also be a rod bearing etc. One way to tell if it is a rod bearing is pull the plug wire on the suspected cylinder. Won't knock nearly as bad if you find the culprit this way. Could also be a valvetrain issue or maybe even the timing is too advanced and what you are hearing is knock.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
