Re: Super A Thermosyphon - Is it working?
Posted by Jimps on January 25, 2010 at 07:56:40 from (216.166.222.115):
In Reply to: Super A Thermosyphon - Is it working? posted by Jimps on January 24, 2010 at 11:29:27:
Thanks the feedback. I know the thermosiphon system is slow, but is there any testing I can do on the block to make sure it's not clogged? If I remove the radiator, can I use a garden hose and send water through the top to see if it comes out the bottom? I know these are not pressurized systems, so will that cause any problems? How easily should the water flow through it? I had the radiator off recently, so it is easy to remove now.
Thanks,
Jimps in GA.
