Phil H said: (quoted from post at 08:27:03 01/25/10) I can't believe all of the ideas???? If you want to clean the tank, just put in some miriatic acid in it. It's cheap, cleans the rust out completely, I guarante it!!! Most radiator shops sand blast the inside, and then put in some sort of sealer. If you have any pin holes that rust through, they solder them shut. After you clean it yourself you can also solder the tank, it's not hard at all. Seal it with POR15, they even have a cleaner you can buy. The POR15 will seal any small pin holes also. Once you seal it, I don't think even sandblasting will take it out. One can did my 18gal tank. Just follow the inst. use a hair blow dryer to remove any moisture. I did it all in a few hours, not days. Let the POR15 cure. It takes several days for that. Once you have done this as they say on the can of sealer, you won't be disappointed. Hope this helps..........
I am a great fan of the muriatic acid myself, but if you go that route, make sure you are OUTDOORS, and have a garden hose with fresh water within easy reach.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
