Posted by MeanGene1 on January 25, 2010 at 09:20:45 from (204.14.185.236):
In Reply to: 1 wire alternator posted by brian 1855 on January 24, 2010 at 15:43:11:
Yep, the only trick to installing a 1-wire is getting the pulley size right- the RPM range of old tractor engines is typically much lower than car or pickup engines, so you may need a slightly smaller pulley- if it's carrying the load and barely charging at idle, you're golden There's also a 24V version of the 1-wire, I have one on my 680E Case, and it works perfectly- the spider's nest of original wiring is still hanging on the engine, but the only thing hooked up is the single wire to the batteries
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
