Posted by mkirsch on January 25, 2010 at 10:37:55 from (64.80.108.55):
In Reply to: Hydralics on C posted by mwilke on January 25, 2010 at 08:42:49:
The bypass block comes with instructions on how to hook it up.
Open center vs. closed center is very important.
Really, it means "open WHEN centerED," as in, the flow through the valve is open when the lever is in the center position. Hydraulic oil can flow through the valve freely.
"Closed WHEN centerED" on the other hand, the valve does not allow oil to flow through it when the lever is in the center position. If you use one of these valves on an open center system, the oil will back up and cause damage to the system.
All the old Farmalls have an open center system. The oil circulates through the pipes at low pressure all the time until a lever is pulled. When the lever is pulled, pressure builds and the hydraulic cylinder moves. Advantage here is simplicity.
A closed center system keeps the oil in a pressurized accumulator, and it only flows when the lever is pulled. Advantage here is the capability for higher pressures, and instant response. It also allows multiple valves to operate at once.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
