Re: Farmall H Stalling Problem
Posted by rustred on January 25, 2010 at 13:54:46 from (74.198.148.46):
In Reply to: Farmall H Stalling Problem posted by Mike Lagree on January 25, 2010 at 13:11:12:
i have seen them where the inlet on the sediment bowl get full of rust and junk. disconnect fuel line at carb and see if you have a good steady stream of fuel running out, if not work your way back.sounds like the flow is not keeping up to what the tractor is using,so then when it stops the carb gradually fills again slowly and your good till it uses whats in the carb then stops.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
