Re: Farmall H Stalling Problem
Posted by glennster on January 25, 2010 at 14:18:05 from (76.217.99.179):
In Reply to: Farmall H Stalling Problem posted by Mike Lagree on January 25, 2010 at 13:11:12:
you need to figure out first if its a fuel problem or ignition. grab a spare spark plug and run the tractor till it stalls. pull any plug wire, stick the spare plug on the wire, ground the plug and try and start the tractor. you you have a bright blue spark, its a fuel problem. if no spark, look to the ignition system. or, when the tractor starts to die, grab the choke and turn it on and off and see if he can keep the tractor running a little longer by using the choke. that will indicate a fuel problem.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
