Usually those old engines have such thick sleeves that if you can not find suitable replacements you can have the sleeves machines to accept a thin repair sleeve. Another advantage to that method is if the pistons skirts are worn too much they can be remachined for use with a slightly undersized bore. You have to have the rings fitted then but that is easy to do.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
