Re: Farmall 966 AB 100 injection pump
Posted by pete 23 on January 25, 2010 at 19:50:42 from (173.87.0.197):
In Reply to: Farmall 966 AB 100 injection pump posted by msb on January 25, 2010 at 19:08:07:
Make sure control sleeve is fully down on plunger in head. Turn control unit arm so pin is at 6 o'clock positon with dot on pin is up. After it is installed arm must rotate full 360 degrees if in stalled correctly. And I will assume you have the internal timing marks lined up.
