Posted by Janicholson on January 25, 2010 at 19:56:27 from (64.61.212.132):
In Reply to: W4 not starting posted by Terry MN on January 25, 2010 at 19:36:32:
One possibility is that the magneto impulse coupling is not snapping at cranking speeds. There is a system in the Mag that holds the magnet with a latch and spring. As the mag turns at low (cranking speed) the latch momentarily holds the guts of the mag, then at TDC of the cylinger, it releases. This windup increases the speed of the magnet in the mag, allowing it to make good spark with near no engine speed (works with hand cranking). If the mag is clearly making this snapping noise when hand cranked, or listened to at the mag when cranking with the starter, it is something else. Pull starting it (no faster than 4 mph in 4th gear) will start it even if the impulse is not operating. This is because the running engine does not use the impulse system as it has enough speed to generate spark. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
