Posted by Bob M on January 26, 2010 at 11:37:40 from (151.190.254.108):
In Reply to: Distributor rotor posted by Rob in Ore on January 26, 2010 at 10:29:49:
Moisture inside the distributor will hasten corrosion of the metal contacts. And if you are subject to salt air out there in western Oregon stuff will corrode even faster.
Also - was the "new" rotor button that rotted away perhaps made in China? Those guys are notorious for substituting dichromate finished steel (and even UNplated steel...) for corrosion-resistant brass that was used in the original ignition parts.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
