SC head removal
Posted by Mark on January 26, 2010 at 16:59:17 from (75.90.232.147):
I suspect a leaking head gasket on my Super C and so, I started to yank the head. Nope..never done this before, but it doesn"t intimidate me...until I get backed into a corner..hehe!
I get everything on the outside loose, pull the valve cover and look everything over real close. There"s no getting that center head nut loose with the rocker arm in place...I cannot get a socket or a wrench on it.
Very well, I loosened all the rockers, took the rocker arm nuts off the studs and the arm assembly refuses to budge. So...just what does it take to get the rocker arm off the studs? I sure don"t want to pry or hammer on it...unless there is a specified manner to do it.
Every head nut is loose except that center one that hides below the center rocker arm support....if I can get it off....the rest should be easy. Thanks.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
