Re: have a130 want something Bigger
Posted by mkirsch on January 27, 2010 at 05:34:57 from (64.80.108.55):
In Reply to: have a130 want something Bigger posted by Kerry (N.S.) on January 26, 2010 at 11:32:08:
My vote would be for a Farmall 350. That gives you a tractor that's bigger, has many modern conveniences, and matches the series of what you already have...
If overhead clearance is an issue, a 350 Utility might be a better choice because it sits lower.
