Re: Distributor rotor
Posted by Brownie 450 on January 27, 2010 at 05:57:23 from (66.43.241.141):
In Reply to: Distributor rotor posted by Rob in Ore on January 26, 2010 at 10:29:49:
Are you sure your distributor isn't 1 tooth out, or the timing isn't off a fraction? These ignition systems can throw a big spark--which can jump a sizable gap. If your rotor isn't closely aligned to the dist. cap terminals when firing, the spark could chew up a rotor pretty quickly.
