Re: Farmall 350 Utility
Posted by formerly ny bill on January 27, 2010 at 10:24:09 from (67.242.110.229):
In Reply to: Farmall 350 Utility posted by Christopher S. on January 27, 2010 at 08:28:11:
a 350 utility will have 28" back tires and the wheel centers are pressed steel and will be bolted to the axle with (i think) 8 bolts. a hi utility will have 38" tires and cast centers that slide on a bar axle, like the farmall models. there were 860 or so hi utilities made. lots more than that of the plain utilities. most were gas.
prices range a lot- from around $1000 for a plain runner, to $25-3000 for a really nice one. tires will cost a bunch if you need to replace them. check the steering box for slop and/or welds. they are the weakest point on the 300 and 350 utilities and steering parts are like hen's teeth.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
