Dick Binfield said: (quoted from post at 20:01:51 01/27/10) I have a Farmall M with live hydraulics and I have intentions of mounting a F-11 loader including the PTO pump. Can I use the F-11 hydraulic tank for the live hydraulic reservior also? Can I plumb the live hydraulic pump into the F-11 system so the loader will operate with the clutch and PTO disengaged thus the PTO is not spinning? The M originally had an older Dual loader with an auxillary reservior tank attached to the Dual frame and to the live hydr pump. I have removed that machine. Thanks
If you are going to run the loader with live pump on the tractor, don't even use the PTO pump, remove it. You will probably have to use the loader hydraulic tank as your belly pump reservoir will not hold enough oil to operate the loader.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
