IH 340 U hydraulic bypass plate
Posted by brian peppler on January 28, 2010 at 04:38:58 from (24.196.158.212):
Hello the past month I have been bringing back to life a IH 340 U it has 3 point with a hydro handle on the right side by the seat that has linkages to the cylinder and valve block in front of the shifter. This is all I have for hydro valves I see on Ebay that some one is selling a by pass plate for a different model do they make one for the 1962 IH 340 U. When I go to IH parts and look at the hydro systems it seems like they had a few different types. Also when I raise or lower the three point it will go up and down great but do you need to move the hydro handle when it's at the top or bottom of it's range mine don't go to center like the new tractors do. I want to put two more hydro valves on for planting then I would use Cross hydro valves on a made up bracket. Or if you have a better idea. Thank you,
