Re: Tel a depth and draft control question
Posted by pete 23 on January 28, 2010 at 18:59:32 from (173.87.0.197):
In Reply to: Tel a depth and draft control question posted by Pete7 on January 28, 2010 at 17:33:11:
The draft control is strictly mechanical on that model and will work with or with out the teledepth setup. If you look at the cam the draft control lever works on you will see that the farther up you pull the handle the more leverage the draft pulling on the hitch will cause the hitch to raise thus reducing the draft load. (cheaters is what we call draft control).
