Someone on this forum has a picture of their Saginaw on an H lifting way more than it should... an entire other tractor!
Lift speed and capacity depend on a few factors:
1. How many cylinders. Two lift more than one, but two are slower.
2. How big the cylinders are. Bigger cylinders lift more, but are slower because the pump has to pump more oil to fill them.
3. How good your hydraulic pump is. A wore-out belly pump on an H will not lift much, and will lift it slowly. A good belly pump will provide you with acceptable speed and capacity.
I recommend setting up a two-way, if not for down pressure, but also for the additional fluid capacity.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
