Re: Front-mounted snowblower again
Posted by Wardner on January 29, 2010 at 11:46:28 from (4.154.244.165):
In Reply to: Front-mounted snowblower again posted by ryanwheelock on January 29, 2010 at 10:49:14:
Throwing snow is a little bit like baling hay. The load on the implement is variable. You need an IPTO so that you can "inch" the tractor forward while the blower is gulping down a snowbank or drift. Side mounted belt pullys de-clutch with the engine clutch. Not a good arrangement.
Live OEM hydraulic power will work under light conditions. Most tractor hydraulic systems are not capable of delivering enough power to be effective for snow blowing. If you drive a high capacity pump with a LPTO it could be done but very expensive. If it is not engineered right, it will be even more expensive. All the components have to be selected using hydraulic engineering principles. If you are asking this question, I don't think you are ready to design a system. I couldn't either because I don't know what the power requirement is for any available blower under all conditions. A satisfactory solution may only be possible with field testing.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
