Posted by Janicholson on January 30, 2010 at 10:57:28 from (64.61.211.127):
In Reply to: hydraulic? posted by dan mcdonald on January 30, 2010 at 06:46:44:
There are vented and non vented systems. In systems that have large capacity there is almost always a vent, in self contained systems with no remotes, there may not be. One way cylinders, with no hose on the non pressure end, and a vent, or atmospheric port, draw their extend volume from the reservoir. This volume is substantial, and would lead to a vacuum in the system, and cavitation in the pump if allowed to happen with no reservoir vent. Generally all one way cylinder systems need vents unless the non pressure end of the cylinder is plumbed into the reservoir, acting as additional volume, and returning fluid to the res as it is being pumped out to the pressure side. The ram of the cylinder takes up volume in the system, so there is somewhat less returning than is sent. In a large complex system this differential in volume can be a problem if all cylinders are extended at the same time. Venting is good but it also provides the primary route for moisture to get into the system. A vent filter with a desiccant is probably best. Systems that routinely operate at full temperature under load heat the water out of the oil. Systems that are worked only lightly will need the fluid changes as it becomes milky. Heating the fluid can drive out the moisture, but care must be taken to prevent flash fires. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
