Re: NF wedge-plate
Posted by Janicholson on January 30, 2010 at 11:26:33 from (64.61.211.127):
In Reply to: NF wedge-plate posted by Leo S on January 30, 2010 at 11:10:23:
The thick to the front.
They increase caster, (like a shopping cart front wheel) they can work to aid stability, but increase steering effort some what at road gear speeds.
It increases self centering.
Real anti wobble is cured by tight shaft bearings in the bolster, wheel bearings with correct preload, balanced good front tires, Steering gear box worm and sector in good adjustment and little wear, Good worm bearings in proper preload, good U joints (and Ujoint to shaft double roll pins)in the shaft, and a steady hand at the wheel. JimN
