Re: M Has Spark and Gas but won't start?
Posted by rustred on January 30, 2010 at 12:56:23 from (74.198.148.45):
In Reply to: M Has Spark and Gas but won't start? posted by Farmall M Beginner on January 30, 2010 at 12:39:42:
start at the tank and work your way to carb. check for good steady stream of gas at carb with line disconnected. check filter at carb where line screws into, next is carb o/h.
