Re: M Has Spark and Gas but won't start?
Posted by ih560 on January 30, 2010 at 13:09:21 from (67.131.50.233):
In Reply to: M Has Spark and Gas but won't start? posted by Merlin in Rushford on January 30, 2010 at 12:39:42:
If the tractor has been sitting for a while, you might be best off to go ahead and pull the carb off and rebuild it. If you do not think you can do this yourself, it is not very expensive to have someone else do it. If you are getting a good flow of fuel before the carb and good spark when cranking (at the spark plug) and no one has messed with the timing, then chances are your carb just need a good cleaning or rebuild.
