Got it done today. Drained the coolant, approx 3 gallons collected, some got away. Removed the inlet casting and used garden sprayer to flush it out through top and bottom openings. Lots of brown/orange water and some chunks of mud and scale. Flushed both ways for about 30 minutes until water ran clear. Check tempertaure probe while I had it out with a pot of boiling water. Checked out OK (it should, it's new, but probably made in China so I needed to verify). Buttoned it all back up and filled with drained 50/50 mix (it was clean) and added a little more to make up for the displaced sludge and escaped coolant. Cranked it up, waited a few minutes to get warmed up and then ran her up to 3/4 throttle. After 15 minutes no movement on temp gauge. So, to accelerate things, I covered the front of the radiator with a trash bag. 10 minutes later the temperature started to rise a bit (still in cool, but movement is good, means it is working). 10 minutes later it was almost up to "Run" level on the temp gauge so I removed the trash bag. 5 minutes later it was back to below cool. That is one efficient radiator! Ambient temperature was 45 deg. I opted not to run a flush kit through it at this time.
So now I know it is working correctly. It is good to be validated with hard evidence. I suspected it was working fine, but just wanted to be sure. Thanks for all the advice and suggestions.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
