Re: 450 power steering
Posted by glennster on January 30, 2010 at 17:30:15 from (99.90.9.153):
In Reply to: 450 power steering posted by oldiron29 on January 30, 2010 at 16:43:34:
on the char-lynn system, it helps if you jack up the front of the tractor to get the weight off the wheels, then slowly turn the wheel stop to stop several times like kirk said.
