Super C Crank Pulley
Posted by deano4863 on January 30, 2010 at 21:15:29 from (76.30.35.249):
I started working on a 53 SC today. Pulled the plugs and looked inside and not too bad. Grabbed the fan and it turns the crank pully but the pistons never came up. This is not good. I put the tractor in gear and rocked it and the motor is locked up. I have read the archives and understand that the pulley is a press fit. Is their a key way? I'm hoping it's as simple as the key was not installed. Any thoughts?
