Re: Super C Hydraulic question
Posted by Andrew Z on January 31, 2010 at 05:33:34 from (64.252.113.90):
In Reply to: Super C Hydraulic question posted by Bruce Arnold on January 31, 2010 at 04:47:54:
They normally prime themselves, iv had Cub's though Super C pumps apart and none have an issue. i know this is dumb, but did you mover the T/C levers back and forth while it was running? Do you have the T/C unit full of hydro fluid? And when you had the pump apart was anything inside badly scorn? you may have a worn out pump however even a tired pump will give some pressure. The only other thing that i can think of is to vent the fill cap while running it and see if that helps, it maybe air bound, personlly never had that happen but its a possible i think....
Andrew
