If you are hooked up to let the pump use the loader fluid tank, you would have enough reservoir to run almost anything so long as you leave the loader frame on the tractor and that reservoir hooked up.
You could run the output line from the current control vale into the input of a new valve and the output from the new valve back to the reservoir. I don't know if you'd have enough pressure to run the baler or MOCO but you'd have adequate fluid.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
