You could be cleaning the cylinder walls of their oil, by dumping gas in it. Thus lowering the compression. Take the plugs out and do a compression check dry and then with a squirt of oil in each one. Then if everything checks out try to start it. I have had this happen a few times when trying when my 200 was sticking float open/closed. Used starting fluid or gas and it wiped the cylinders. A squirt of oil in each one and it fired right up.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
