Re: magneto or coil?
Posted by mike paulson on January 31, 2010 at 07:48:51 from (69.206.144.157):
In Reply to: Re: magneto or coil? posted by El Toro on January 31, 2010 at 06:40:00:
so El Toro being that the generator has been removed and it looks like i don't have a mag means i have no charging system....you think if i keep the batt well cahrged i could run a set of headlights on this and for how long?
