Posted by John T on January 31, 2010 at 14:14:52 from (71.55.31.109):
In Reply to: Re: OT-Aux Generators posted by rhouston on January 31, 2010 at 14:03:53:
On a small genset its often at the receptacle or its box that they use a jumper that bonds the Equipment Ground (Green) to the Neutral (White) and the Ground is bonded to the metal frame somewhere (maybe in the receptaclebox???). The bond that should be severed IFFFFFFFFF the genset back feeds a panel via a 2 pole x fer switch or 2 pole breaker is the Neutral to the Ground i.e let the Neutral float. The equipment ground is still tied to the iron frame just as metallic boxes and conduit etc are tied to their equipment ground, its just that the Neutral isnt supposed to bond to it in the case above. If the genny is used free standing just by itself then its Neutral should be bonded to its frame and the Ground conductor and thats the normal condition as they are shipped.
It will still work mind you, Im only describing the proper NEC way to do it for safery reasons it would take too long to explain here
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
