Re: What is the difference?
Posted by Harold H on January 31, 2010 at 16:17:16 from (98.18.178.17):
In Reply to: What is the difference? posted by ADLM on January 31, 2010 at 12:54:03:
You should be able to get 30 weight oil most anywhere. On any multi viscosity oil, the actual oil is the viscosity oil of the lower number, with additives to make it perform like the higher number at higher temperature. For example 10w30 is 10 weight oil that acts like 30 weight at high temperature, 15w40 is 15 weight oil that acts like 40 weight at high temperature. For constant loads in warmer climates I would use the straight 30 weight. For cold starting and in cold temperatures I would use the multi grade 10w30 or 15w40.
Harold H
