Re: Old Barn Repair - Update
Posted by Formerly PaMike on January 31, 2010 at 16:38:16 from (24.152.202.123):
In Reply to: Old Barn Repair - Update posted by Dellbertt on January 31, 2010 at 07:31:38:
We just had a ton of work done to our old bank barn. A bunch of the floor beams were rotted off where they set on the wall. About 10 new oak beams fixed that. Then they went into the basement. The posts had gradually rotted and settled. This pulled the whole barn down. We actually went upstairs and found a vertical beam pulled out of its joint because the post below it in the basement had settled. A bunch of jacking and a new post and fotter solved the problem. I think they jacked the beam 4 or 5 inches to get it back up where it should be...It will be good for another 200 years now...
