Re: Ballast resistor
Posted by Bob on January 31, 2010 at 17:48:13 from (69.178.228.68):
In Reply to: Ballast resistor posted by Whiskey Bent on January 31, 2010 at 16:37:59:
The way you wrote that it sounds like the ballast resistor became hot and began to smoke AFTER the engine "died".
WHY did you leave the ignition switch "ON" after the engine had stopped???
If the engine stopped at a position where the points were closed it is NORMAL for the resistor to get quite hot if the switch is left on.
It SHOULDN'T have burned out, though.
Sounds like the coil may have shorted out, also check for a shorted wire from the resistor to the coil.
The NAPA # for a REAL 12 Volt coil needing NO resistor is IC14SB. Should be under $20.00.
(The core the resistor is wound on is a heat-resistant glass or mineral fiber core and it seems odd that that would have melted!)
