Re: Ballast resistor
Posted by Whiskey Bent on January 31, 2010 at 19:29:16 from (69.77.235.164):
In Reply to: Ballast resistor posted by Whiskey Bent on January 31, 2010 at 16:37:59:
Bob, the coil you talk about has a built in resistor? I have some 12v coils, but then I would still need a resistor between the coil and the points correct?
