Re: lube confusion??
Posted by mkirsch on February 01, 2010 at 05:58:50 from (64.80.108.55):
In Reply to: lube confusion?? posted by mike paulson on January 31, 2010 at 18:44:13:
HyTran is short for Hydraulics and Transmission.
Where you put it is pretty self-explanatory once you know that piece... It goes in the hydraulics and transmission.
IIRC the 300 and 400 tractors called for SAE10 motor oil with some additive in the rear end. Use Hytran.
IIRC the 300 and 400 tractors called for "Touch Control Fluid" in the hydraulic system. Use HyTran.
SAE90 gear oil is still around.
SAE30 engine oil is still around.
