Posted by jdemaris on February 01, 2010 at 07:00:45 from (67.142.130.12):
In Reply to: Ballast resistor posted by Whiskey Bent on January 31, 2010 at 16:37:59:
Any good ballast resistor will smoke and heat up if you leave the ignition on, without the engine running, and the points happen to be closed. At it heats, its resistance also increases. Ballast resistor is designed to get hot under a high current load. It won't do that with the engine actually running. It works as a varible load-sensing current regulator, and to a degree, adjusts to engine spark demands.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
