Re: Restoring a International 140 Seals, final drive
Posted by jfay on February 01, 2010 at 12:52:43 from (72.72.76.80):
In Reply to: Restoring a International 140 Seals, final drive posted by Farmer Man on January 31, 2010 at 19:48:38:
this is a fairly easy job, you will need an engine hoist though to remove the final drive. Search through the archives for Super A or 140 final drives and you can get a lot of information. There is only one spacer which goes between the drive gear and the inside bearing. Sounds like yours might be missing, but the axle should be tight when you put it all back together. Here is a link to a post regarding the seed plate drive and how to install a seal.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=744824
Jamie
