Re: FarmAll M turns off after 60 seconds
Posted by old on February 01, 2010 at 12:53:54 from (4.245.0.113):
In Reply to: FarmAll M turns off after 60 seconds posted by RolandM on February 01, 2010 at 12:28:37:
You need to do the normal trouble shooting. #1 check for a good blue/white spark and then #2 check that you have a good steady flow of gas from the drain plug in the bottom of the carb. One of those will most likely be your problem and once you figure that out you then need to find out why your missing one of them
