Re: FarmAll M turns off after 60 seconds
Posted by El Toro on February 01, 2010 at 15:36:35 from (74.103.74.58):
In Reply to: FarmAll M turns off after 60 seconds posted by RolandM on February 01, 2010 at 12:28:37:
If you didn't remove the tube fitting where your gas line connects to the carb the screen behind that fitting may be plugged with rust & dirt. Hal
