I actually have three of the "cutdowns". I described the first one that I built in the first e-mail. I forgot to add that when I tried to buy an I12, it started off at $3300. I desided to build my own. Since then I have built a "rowcrop" version with 24 inch tires and the same cut down frame. Again I used a 16 hp Kohler engine. My last reactor was a "lowboy" I used the same f12 frame but cut it down to the point where I had only 4 inches of ground clearence. I used the tires off my son's SUV. I used a padded seat from an old cub cadet and again a 16hp Kohler engine. Since the center of gravity is so low, it pulls like you wouldn't believe All three of my tractors have the engine mounted on a flat plate with bearings on one end. The other end is raised and lowered via a cam mechenism fastened to hand operated clutch lever. I use at least 2 belts so that the power is transmitted to the bevel transfer gear. The tractors run at least 8 mph. Send me your e-mail address at: dalsfarmallsf12@yahoo.com and I will send you a picture of the rowcrop version.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
