Re: un-siezing an engine
Posted by El Toro on February 02, 2010 at 03:50:44 from (74.103.74.58):
In Reply to: un-siezing an engine posted by kennebunksawmill on February 02, 2010 at 03:02:21:
If it was ran low on oil it may have spun a bearing. Drain the oil and see if any metal flakes are in the oil. You can drop the oil pan and take off the bearing caps and see what shape the bearings are in. If the crankshaft is scored from lack of oil you will need to pull the engine. Probably can be rebuilt. If the shaft looks ok you need to retorque those bearing caps. Pull the sparkplugs and fill the cylinders with ATF and let it soak. Hal
