Re: Cub steering
Posted by sgt bull on February 02, 2010 at 06:15:47 from (75.207.238.215):
In Reply to: Cub steering posted by darock on February 01, 2010 at 04:53:35:
Not sure if you have already taken anything apart, but the steering shaft bushing, where the shaft enters the bolster, has a clearance gasket in it that adjusts endplay of the steering shaft. Loosen the two cap screws...if it steers easily afterwards, you need an additional gasket. If you haven't had that apart though, it is unlikely to be the problem. Insufficient clearance will essentially clamp the shaft in position.
