Re: un-siezing an engine
Posted by Janicholson on February 02, 2010 at 08:16:06 from (199.17.6.222):
In Reply to: un-siezing an engine posted by kennebunksawmill on February 02, 2010 at 03:02:21:
Success ranges from minimal problems putting a main bearing in it with poliching the crank in the block, to full remanufacture. The ods with the expense go up when it has been heated radically, or if it ran so long W/O oil that all bearing surfaces and cam contact on lifters, and piston scoreing took place. 10% chance of a bearing replacement and polish W/O full disassembly. JimN
