Re: FarmAll M turns off after 60 seconds
Posted by mkirsch on February 02, 2010 at 09:43:37 from (64.80.108.55):
In Reply to: FarmAll M turns off after 60 seconds posted by RolandM on February 01, 2010 at 12:28:37:
How long after the tractor stalls do you have to wait before it will start again? Right away? A few minutes? 30 minutes? 1 hour?
There are two common problems that it might be:
1. The ignition coil is overheating.
2. The flow of fuel to the carburetor is slow.
By the way, we don't "turn on" a tractor. There are other things we "turn on" like a light, or, well, that would be inappropriate for this group to say more...
It's common to say that we "start" the tractor. Same as we start the car.
When the tractor stops running and you didn't shut it down, it "stalls."
I'm guessing you're not from the USA. Am I correct? It's very very very uncommon for someone from the USA to "turn on" or "turn off" a car, unless they've never seen a car before in their lives.
