Thanks for the info. I actually had not checked the stream. Last night I disconnected the fuel line from the fuel shut-off valve and then opened the shut-off valve and to my suprise there was only a trickle. I blew some air pressure into the fuel tank with the valve open which increased the fuel stream a bit. After that I reconnected the fuel line and started up the tractor. It didn't turn off anymore when idling but once I increase the throttle it does turn off after a while. Which tells me that there is still not enough fuel making its way to the carb. I am going to work on the tractor later this week. I think the problem is the fuel shut-off valve. I am going to replace and let you guys know how it went.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
