Hi Neil, I don't have book for D-179 but have book for the 4cyl version D-239. The cyl head bolts are to be tightened in 3 steps, 30 ft-lbs, then 60 ft-lbs, then 90 ft-lbs. There is a bolt tightening squence. Both exhaust and intake valves are set to 0.012 inches. Flywheel retaining cap screws 110 ft-lbs. The main bearings have different settings depending on the type of cap screw all with lubed threads, tighten in 3 steps, 30 ft-lbs, then 60 ft-lbs, then final step as below: Necked down bolts marked: 10.9K set 80 ft-lbs, 12.9K set 100 ft-lbs. Pitch diameter bolts marked: 10.9K set 105 ft-lbs, 12.9K set 141 ft-lbs.
Necked down bolts have a shank diameter of 0.410 inches. Pitch diameter bolts have a shank diameter of 0.500 inches.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
