Re: Student Farmall H project
Posted by El Toro on February 02, 2010 at 14:18:26 from (74.103.74.58):
In Reply to: Student Farmall H project posted by djsinseia on February 02, 2010 at 09:40:24:
You need to get those manuals that was suggested. I would fill the cylinders with ATF and let it soak. You probably need to split the tractor and tear that engine down completely.
You need to a lot of pictures even some video and take a lot of notes and makes sketches. Keep all the parts from engine separated and marked as to where they were removed. Cardboard
boxes are fine and can be marked. This will save a lot of time when you get in the rebuild.
Need to have head reworked, block cooked, new cam bearings installd, crankshaft cleaned and measured for wear. Your local auto machine shop can get new bearings. Hal
